I would echo the opinions on Echo paddles.
I have been very hard on paddles in the past and my Echo paddles have been both durable and a pleasure to paddle with.
They are made in a small "off the grid" shop and carefully custom crafted.
They are more costly than some other paddles... but definately worth every penny... ask Santa for one next year!
jim
Good whitewater paddle?
H2O Team pro paddle
I'll vouch for that H2 O paddle. The blade has great initial catch ( it is really good for shallow water in that respect) and is pretty tough. My son has worn out 2 blades -- he does a LOT of creeking with it --, but they are easy to replace -- you can buy blades from H2O for around $50 and epoxy them on, yourself. Just cut the old worn-out one off. You can'd do that with most other paddles mentioned in this thread. It feathers surprisingly well through the water -- better than the Werner that I had before. I like the bend shaft, but I go back and forth between that and another straight shafted paddle. I also have a Galasport, which I like very well, too. It feathers through the water and finds the surface easier that either the Werner or the H2O. I use the H2O for shallower water and the Galasport for deeper/ more aerated water. It feathers so well that what used to be a roll with my Werner is a brace with the Galasport -- I can get it tothe surface SO fast... I love them both and would recommend either over the Werner Bandit, which is what I started out with.
paddle
well, you've probably watched the video already but until i get the new one up, check this if you haven't seen it.
http://www.youtube.com/watch?v=LMr2eiIRtqg
I'm really lovin' the werner bandit. All three Scriver's use werner bandit and none of them have broken one yet, which is pretty amazing.
paul
paul
bubblestreet.ca
theracane.ca
theracane.ca
