what is a canoe/kayak
- rockyboater
Here is my take: If you paddle with a single blade, you are a canoeist, period. Some canoeists break out a double blade on flatwater, just to make it easier to rack up miles. But they have the single blade skills when it counts.
If you paddle with a double blade, sitting on your butt, you are kayaking. Most kayakers, by definition, do not have the skills to paddle successfully with a single blade, so you rarely seem them trying to do so.
Some boaters have strong skills with both single & double blades, but as a general rule, a canoeist can "get by "in a kayak but the reverse is seldom true.
As for boats, with race/competitive boats there is usually a specific definition of what qualifies for what class. Other than that, it is pretty much whatever. You can create whatever you want & call it what you want, altho since kayaks are designed to be paddled sitting on the bottom (as opposed to a thwart), and canoes from a either kneeling or a thwart-type "seat", the hull designs that work most satisfactorily, at least for performance, will differ. Not that that keeps folks from trying.
Things I have seen (many of them for the hades of it): John Kennedy paddling the Ocoee in a kayak using a canoe paddle. Jon Lugbill placing second in K-1 in a slalom race -- doing all the hard moves with the left blade. Ron Lugbill kneeling in the short-lived "Kneeliac". Some OC-1ers paddlling stand-up years & years ago on flat & 2-3 water -- long before the current interest in stand-up boards.
Hey, its all water out there -- the real distinction that matters is: those who can paddle single blades & those who can't!!
Just control that upstream edge...
C-1's are the Gods of the River
RodeoClown
- BlackFly Canoes
What if you're standing up in a canoe and poling?
What if you're kneeling on a stand up paddle board (because you fell off) and paddling with a single bladed paddle?
What if you kneeled on a sit on top and used a single bladed paddle?
If you paddle a raft by your self with a single bladed paddle, are you canoeing?
High Kneeling?
Hand paddling?
What if you're hand paddling a c-1? Should you use one, or two hand paddles? If you're only using one hand paddle, can you still use your other hand, or would you be kayaking then?
High Kneeling?
Hand paddling?
kanukyotee
This is one of our cyclical subjects - I haven't reviewed the archives to check the period on this one, but I'd guess 6-8 months. I wasn't going to post but I'm weak.gumpy wrote:again?
I don't know about defining boats, but I'm a canoeist regardless the craft I'm in.
