L'edge grab handles
- Yukon
- Yukan Canoe
L'edge grab handles
I see in pics from ALF Ledge grab handles going across the boat instead of with the boat. Which makes for a way more comfortable position. Is this a change from Esquif or a personal custmization. When they go with the boat they are down right awful.
- Smurfwarrior
- Smurfwarrior
funkidreadz
I added additional rope handles on the thwarts, thus making the L'Edge way easier to pick up and manoeuvre, onto your shoulder, car, luggage trolley, tricky portage etc.
I also have them on my Taureau
Does turning the end grabs really make it more comfortable carry the canoe?
It will for sure reduce the chance of catching your paddle when making a lightening quick emergency cross deck stroke, adding rope handles will probably increase the chance, I used to remove the rope grabs from my SpanishFly and mount them further back and turned 90degrees back when I was paddling a lot of rodeo because I caught my paddle in the front rope SO many times.
Paddle safe
James
Paddle safe
James
Hi Yukon,
These L'Edge grab handles that you've seen photos of were switched around at Louie's place during our late night ALF outfitting parties. It makes grabbing, dragging and lifting the boats much easier on the hands. Rope grab loops are a great addition too but if you're going to leave the metal handles on the boat you might as well make them a bit more pleasant to use.
Johno Foster
Johno Foster
- Yukon
- Yukan Canoe
Hi James
Good ideas, How did u get the rope handles into the front of your Taureau? Did u take out the saddle?
On the Ledge turning the handles 90 degrees would allow you to carry or drag the boat like a suitcase instead of your hand sliding into the small part of the handle and pinching.
Craig how strong are the anchors or nuts molded into. If they are used for rescue purposes what kind of force can they withstand and has that been tested?
