Can anyone describe this canoe's strengths/weaknesses and how it may work for a newbie 9 year old. I think it's rated around 70-110 lbs paddler if I remember correctly. Are there other options for small canoeist. My daughter isn't quite yet 70 lbs.
Its a kids version( but a little different) of the Bulldog, and I've had one of those. Get it, its the only kids whitewater canoe out there. Unless you want to chop a canoe in half, cut out the center and weld it together. The SL'Edge worked out great for a 10 year old at ALF. But, the Splash is what you need.
Or you can buy an INFERNO from Millbrook Boats. Although, it's 11' long, but you can purchase a bare hull that I could cut down to a 12" depth. Kids lay-up, bare hull - $800 - hull only, provided you want to put your own rails on. That is, if you want a composite boat, and a bare hull.
thanks,
kaz wrote:Or you can buy an INFERNO from Millbrook Boats. Although, it's 11' long, but you can purchase a bare hull that I could cut down to a 12" depth. Kids lay-up, bare hull - $800 - hull only, provided you want to put your own rails on. That is, if you want a composite boat, and a bare hull.
thanks,
Jkaz
I'm assuming from the website description that, at adult weight at least, the Inferno is an edgy, high performance race boat, right? With a 55lb or 95 lb kid in it, does it become more forgiving? Also, how well does a composite boat hold up to running class 1-2 rapids without a pilot? Assuming it's properly bagged out, of course...
