abs protection
abs protection
What kind of paint do you use to cover the areas on the Royalex where the vinyl has been rubbed off? I mostly see something that looks like black paint being used although it looks a little thicker than paint.
The ABS-acetone slurry is used more for when the whole boat has worn away, it's overkill for worn vinyl.
Any plastics paint will do a decent temp job to re-cover the ABS. Around here "Krylon" seems to be a common brand, but most hardware stores probably have a can of paint that you copuld use to paint plastics.
Note that it does wear off again faster than the vinyl coating would, so if you're really concerned about every bit of ABS that shows through, you'll need to re-paint regularly.
Pat.
Pat.
I don't see how ABS slurry is overkill. I have some mixed up in a mason jar, and using a cheap brush, paint it on easier than spraying Krylon. As far as Krylon, I've found the Red clogs easily, which is why all my boats are turning green...with black racing stripes
http://good-times.webshots.com/photo/28 ... 6337OPdMcj
Folks just reminded me recently of Legos (abs) in Acetone for working up the surry, verse the black. Multiple colors can be use to mix up a match (teal, etc). works well and better protection then just paint for the longer period. Apply multiple light coats for best protection. If the boat is not getting much use paint would be easier, just comes off quicker on rocky runs.
No set match ratio that I know of. I think it depends on how faded the boat is.
I had to try 2x to get it right but now its pretty darn close. I add too much green at first. So the ratio is more a number of white, a few blue and then a green or two. Depenancies are size of mix your working with (Acetone and evap off), size of legos used (the reg 8 pin size verses 4 pin), how faded the legos are themselves, etc.
Once I got that match (in a glass mason jar) I have enough of it and let it sit on the self for future use (along jars with some blue, some red and of course black).
I might have to add more Acetone to reactive the mix but I have the color I want. Hopefully the self life is that of legos themselves. We'll have to see on that one.
PS: Thanks to Scott B for reminding me of the process.
- solo_konoe
