break down canoe paddle
I recently bought an L'edge and I would like to purchace a servicable break down canoe paddle that I hope I will never have to use. I am looking for suggestions and prices if you know them.
Werner Nantahala Breakdown
I bought a two-piece breakdown version of Werner's Nantahala paddle through NOC earlier this year. It's a more-than serviceable option.
That's the funny part about the whole AB debacle. The first breakdown AB made for me (this was all being handled through a local paddling shop) had a decal on it that said 58", which tipped me off that it might not be 57" and, measuring it, it wasn't. The retailer ordered me a second one at that point and when it arrived several weeks later, it had a 57" decal on it. I pulled out a tape measure just to check and it was a full 58". Go figure.
A couple things I will say about AB that are very positive are:
1. They don't charge extra for their breakdowns. Eddyhops points to a site that sells AB breakdowns for $139. Mine was $99 through my local paddle shop, same as what a single-piece paddle cost.
2. AB was flexible on where to have the paddle break. I told them I wanted it to separate 8" up from the blade and they did that.
3. It's easy to shorten the paddle yourself.
Two reasons. One it made the paddle closer to equal lengths (not very close, but enough that it shoves really nice in the bow of a Prelude). And two, having some shaft on the blade end makes it a little easier to secure in the boat. AB likes to do it breakdowns by simply have the blade insert into a full-length shaft. That's what you'll get if you don't say anything.
Hmm.. any other thoughts on the _where_ question of putting the break in the paddle? I assume two-piece is better than 3 if you can fit it.
And any other success stories of getting your break-down with no additional cost? If someone can name me a retailer in the greater Asheville area that can order me a $99 break-down Carbon Edge, I'm ready to pull the trigger.
might wanna get a 3pc. they break down to just about the size of the blade.
it'll fit in more boats, and you presumably will have it much longer than your current boat. who knows what you'll be wanting to paddle next.
might as well make it easy to pack away, because you will always be carrying it and hardly ever using it.
it'll function just as well as a 2 pc.
- FullGnarlzOC
Ab no longer makes the 3 piece (2 piece is a better quality paddle anyways).
Will post where you can get some at this time whenever I hear back.
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
