that's one of those things the ACA requires you to use for racing...kaz wrote:What's an air bag?
straps vs bulkhead
Re: straps vs bulkhead
Craig Smerda wrote:that's one of those things the ACA requires you to use for racing...kaz wrote:What's an air bag?
WIN!!!!!
JD
I use both because I`m always paddling different boats. ya`ll are to funny
how about using airbags to securely keep yourself in your boat?
wait a MINUTE...
wait a MINUTE...
Ive been wondering if you could affix a Jackson Happy Feet to the bulkhead(between the foam and your thigh). This is then inflated and squished around till it fits what ever you happen to be wearing that day.
GW
Go for it
take pictures
and don't be shy.
take pictures
and don't be shy.
worCstation - straps or bulkhead?
- BlackFly Canoes
I actually do that... kind of.Craig Smerda wrote:how about using airbags to securely keep yourself in your boat?
I pull the corners of the front airbag back though the knee holes a bit. Once I'm in the boat, I can blow it up to get the desired fit. Also, since I don't attach the top of the saddle to the thwarts, theres a bit of 'play' in the bulkhead and also the back of the saddle. Blowing up the airbags takes the play out it, but based on more or less air in the bags, I can adjust how tightly the saddle fits. On days when I'm wearing a drysuit and lots of layers, I don't have the bags blown up as much as when I'm wearing shorts. Works pretty well for me.
