LF Electric bilge pump installation kit
windowshade
Post by windowshade »
Paul, in Ottawa
Bob Wiggins
Re: LF Electric bilge pump installation kit
Post by Bob Wiggins »
windowshade wrote:LF Electric bilge pump installation kit
Paul, in Ottawa
what, exactly, do you need? it isn't hard to get the parts yourself and link them together.
windowshade
I just bought an Esquif Detonator and since I'm gonna spend a lot of time "upsidedown, then right side up" in it, I thought I should get an electric bilge pump installation kit in it... Esquif sells its "kit" for around "$300" but I think therre's got to be a cheaper way to outfit your canoe with an electric bilge pump! Am I wrong??
Paul :D
mr ray
Post by mr ray »
windowshade wrote:Esquif sells its "kit" for around "$300" but I think therre's got to be a cheaper way to outfit your canoe with an electric bilge pump! Am I wrong??
Paul :D
Totally. I'll help you out and sell you my special budget kit for $200. :D
Actually, there are some build threads in the C Forum. It's easier to do than you might think. It depends on how polished you want it. I've slapped a fugly one together the morning of a trip in 30 minutes. Search a bit and post (or even pm me) if you have questions. Glad to help.
Or if you don't want to DIY from scratch: http://jtkcanoes.110mb.com/#Products
-Ray
windowshade
Thanks Ray! I'll check out your link! Like almost 50% cheaper!
Paul :D
dirk
Post by dirk »
I followed these directions (but used only one pump). Easy to follow and works well. Roughly $100 in parts (several years ago).
http://www.cboats.net/media/pdfs/moneypenny/dps.pdf" onclick="window.open(this.href);return false;
Austin, TX
OC1
windowshade
Whoa, good How-to!
I will try this.
Thanks!
Paul
jknkboaters
Post by jknkboaters »
-Ray
The website mentioned by Ray has moved to:
http://jtkcanoes.weebly.com/products/
It also lists a lot of questions about batteries and the maintenance required for an electric bilge pump system.
Here is one tip - keep your SLA batteries fully charged in storage and between trips. This will increase the life of the battery at least 50%.
jknkboaters
