COMPOSITE CREATIONS BULLDOG CANOE FOR SALE
Composite Creations Bulldog whitewater canoe for sale!(picture a 10 foot composite/kevlar ocoee)Used but in GREAT condition!Retails for over $2000!Asking $700.....Mike Yee outfitting picture in reply below....
Pierre LaPaddelle
Re: COMPOSITE CREATIONS BULLDOG CANOE FOR SALE
An unsolicited testimonial: (Dang -- there I go usin them big werds agin!)
I bought a used Bulldog last year, thanks to some great Pony Express work by cheajack and Smurfwarrior.
I LOVE this boat -- it's shorter and lighter than the Ocoee. Surfs like a dream. Lively, yet solid and predictable. Rolls well.
This might not be the boat for you if you like bouncing down shallow or abrasive streams, but -- if the water's deep enough, it's a great hull.
Rick
Rick
C'est l'aviron. . . !
BAD paddle
Where is the boat located?
Thanks for the interest.The boat is located in Lexington,Kentucky.
Boat still for sale!
- Smurfwarrior
Another testimonial... unsolicited I might add.
I've owned one and paddled two (Pierre's).
Mine was the first boat, or at least a very early model that the owner of CC paddled and this one here for sale has all the fancy upgrades that I DREAMED that mine had had. The smaller cockpit area/larger tanks, the shorter inside sidewall height... etc. With the smaller cockpit, a bulkhead setup would be super easy to make, using the front wall to glue the foam to. I mounted hatch covers on mine and inside storage was excellent. I could fit a two piece break down paddle in mine. If mine would have had these updates, I'd still own it.
Great surfing boat with enough edge to control it on a wave, retentive enough in a hole to stay and play yet not trippy enough to give you mandatory roll practice. Stable downriver too.. Mine would roll up with only a few inches of water in the bottom, not as dry rolling as the L'Edge, but I would assume with the changes made that this would roll as dry as the L'Edge. It makes a cool 'thunk' noise when you land a good boof. Always made me smile...
Now, it only I had $700
- bigspencer07
Sure looks like a boat design ready to be poly-ed
Just out of curiosity, 'cause I really don't need another boat (although "need" can be a very flexible concept) About how much does it weigh?
Ah, I see from the website it's supposed to be ~ 44 lbs. Does that seem about right?
RobertM
(also, oddly enough, in Lexington KY)
RobertM
Yep,44 lbs. seems about right!Sent you a pm as well!
I haven't spent much time using the PM feature on here, perhaps I'm not using it correctly, but I didn't see your message.
I'm sending you a PM, to see if it goes through.
RobertM
RobertM
Got your pm and sent you one that went thru this time(I think).
Boat has been SOLD!!! Thanks to the GREAT buyer who also took a redline C-1 home with the bulldog!!Thanks for all the interest and HELP!
