T-Grip Attaching
- CurlyFries
T-Grip Attaching
Recently cut down an aquabound edge. I've tried using two types of glue with no luck.
http://www.biosafe-inc.com/marine.htm
- Waited ~ 80 hours but it came right out
http://www.canadiantire.ca/AST/browse/4 ... ?locale=en
- Gave it 16 hours and it felt bomber. Paddled on it today and the grip twisted 90 degrees mid run. It sucked.
Any tips on attaching it?
Dave
Dave
Re: T-Grip Attaching
I'd try 3M 5200, West System epoxy maybe with some high density filler, and potentially some form of mechanical attachment, i.e. putting a peg through the grip/shaft.
Do you have a picture of the joint?
EDIT: I should make it clear I didn't mean try all those things at once... although then it would be REALLY secure.
-Anthony
- CurlyFries
Yea I was thinking about putting a small bolt or pin through. Nervous it would make the shaft split though.
What do you mean by high density filler?
Here are some pictures.
![Image](http://i757.photobucket.com/albums/xx219/curlyfriescanoe/IMG_0433.jpg)
![Image](http://i757.photobucket.com/albums/xx219/curlyfriescanoe/IMG_0432.jpg)
Dave
Dave
I'd try roughing up both surfaces with some low grit sandpaper, cleaning both with denatured alcohol, and using a different epoxy (West System).CurlyFries wrote:.....
- Smurfwarrior
I attach mine with West Systems Gflex epoxy with a couple tablespoons of Colloidal Silica filler/thickener thrown in to make it like a paste instead of a liquid, stays where its supposed to much better like that. The Gflex kit comes with a container of the thickener. I always then add a small metal spring pin through the shaft and grip peg to ensure it doesn't come out or twist. Never had one fail.. check out my review of the Core paddle to see the pins and all that.
Best of luck!
Best of luck!
- CurlyFries
Sounds like west systems Gflex is the way to go... But I have never seen it for sale in Ontario.
Any suggestions?
Thanks for the input so far,
Dave
Any suggestions?
Dave
- CurlyFries
Hey Smurf, not sure where to look. A link would be much appreciated!Smurfwarrior wrote:I always then add a small metal spring pin through the shaft and grip peg to ensure it doesn't come out or twist. Never had one fail.. check out my review of the Core paddle to see the pins and all that.
Dave
![Image](http://ecx.images-amazon.com/images/I/31zqMuCkUvL._SL500_AA300_.jpg)
"404 High-Density filler is a thickening additive developed for maximum physical properties in hardware bonding where high-cyclic loads are anticipated."
I'm pretty convinced you can use that with some west systems (not gflex, just the 105/205 system) for just about anything and it will be stronger than the pieces you are bonding.
Make sure both pieces are really roughed up and it should do the trick.
-Anthony
I used a long pop rivet when re-attaching T grips to Norse paddles. Just one is enough.
- Smurfwarrior
viewtopic.php?f=2&t=7965100&hilit=core" onclick="window.open(this.href);return false;
Well there is the link, but I just noticed that I have the spring pin covered up by the heat shrink covering in the pics...
Anyway, I do think that standard epoxy should be just fine in securing the grip, just don't rely on the adhesive to hold it, give something physical to add to the security of the bond. Its just too important for it to stay in place to trust only one method of securing it.
LePage PL Premium 100% polyurethane construction adhesive. It expands as it cures so watch for squeeseout. Fills any gaps and is waterproof. Should be availalbe at Home Despot.
JB weld was recommended here. I used it for wood t-grip to Werner Bandit shaft (fibergass?) no failure one very solid year later. Tricky to find a way to let it set up square. You might think about that ahead of time. I used rubberbands and luck.
- CurlyFries
Used one of these bad boys
http://www.canadiantire.ca/AST/browse/3 ... ?locale=en
As well as epoxy. Then sealed it all with a waterproof sealant. Then electrical taped it all.
Overkill and bombproof.
Dave
Dave
That's a great fastener idea. Thanks.
I replaced a T-grip somewhere around 10 or 12 years ago using West Marine Epxoy and its still rock solid.
You will need to remove the remnants of the previous glue jobs. That should roughen it up enough to get a good hold. I had tried some other glue first (I can't remember what) and had results similar to yours.
