Can anyone give me some insight into what size skirt the Perception Slasher C-1 takes? The only information I can find is from this list right here: http://www.mountainsports.com/skirt-fit-list.htm" onclick="window.open(this.href);return false;
That list says "O-325, DO-325" for the skirt size, which doesn't really help. Thanks A lot for the help!
Re: Perception Slasher C-1
I have used skirts on Slashers that were made for a Gyramax (tight) and a Cascade (just right). An "old school" (small) slalom C-1 skirt will probably not fit.
Seeing as how that generation of C-1's generally had very squared-off cockpits, that might be a length and width measurement, but I can't make sense of the numbers. 325 mm is ~12.75 inches, which would be too narrow, but 32.5" would be way too wide. Unless those are radius measurements instead of diameter? That would make the cockpit 25.5" which still sounds a bit too wide.
Shep
Shep
Any old slalom skirt will generally fit... whether that is "well" or "well enough" depends on the vintage.
If you want any measurements let me know specifically what you want and I'll drag the Slasher down and measure it. I need to shuffle some boats anyway:)
