Applying Waterproofing to Drysuit
- fleckbass
Has Anyone applied Nikwax TX Direct spray-on to a Kokatat Gortex Drysuit? Kokatat recommends this after "wetting out" starts to occur. I'm leary about the "ironing-in" process.
coloradopaddler
the only time i re waterproofed my kokotat gore tex dry suit i used a wash in nikwax product. i've seen that direct spray on and i don't want to use it either. if i were you i'd look for the wash in type, it lasted a long time!
- busterblue
Hi. I'm a long-time lurker. This is my first post.
By chance, I recently attended a drysuit care and repair clinic hosted by our local paddle shop. The Kokatet rep urged us NOT to use wash-in durable water repellent treatments. He said it would impair breathability: DWR should only be applied to the outside layer.
Also, he was skeptical of DWR products on a drysuit in general, because they tend to wear off fast. The suit is still waterproof, even if the outside layer is wetting out. The only problem with wetting out is that you may feel colder due to the evaporation.
That said, I haven't used DWR on my drysuit yet. What do other folks think?
coloradopaddler
i just passed along what i had done, take it how you will. the nikwax waterproofing wash in formula that i used is made for gore tex materials. it has worked great on my dry suit and when the time comes that is what i'll use again. i don't want an iron anywhere near my dry suit, it's my thirteen year old baby and it's still going strong!
You can iron - on LOW
but keep it away from the gaskets! Often you can wash the garment in nikwax techwash then hang to dry and then use a low iron to revive the DWR without using the DWR revival stuff at all, just getting the dirt off and a little heat can bring it back to life again.
That said I've used the wash in product many times and ironed many times on LOW with no ill effects.
But be aware, once it goes the first time, it never beads water for as long as when new.
One trick for the wash in is run the wash cycle and open the lid before it goes to rinse. Let it soak 30 minutes then finish the cycle. Seems to last a bit longer this way.
- fleckbass
Hey, Jim P! Are you apllying the iron directly to the suit? I thought about putting a towel between the two. The suit is really getting wet. It was beading when I first got it but seemed to wet out after 5-10 uses? Never washed it yet. It is in it's second season. Looks like Kokatat recommends a front loader. Are you using a top loader? Gentle Cycle? I'm just afraid to do anything to this expensive piece.
