where can i demo
where can i demo
WHere can I demo a l'edge, option, or octane? Still considering the probe 11, but would like to try out some of the "plastic" boats. people say they are stable, but how are they in comparison to the detonator and the probe? Thanks again, Sandra
Re: where can i demo
Where are you located?
I gather you are somewhere in Canada. Jeremy is in NH, and usually has demos of everything on hand. I haven't paddled a detonator, so I can't compare, but, I am under the impression that the forthcoming Octane 85 will be more or less as stable as a L'Edge, and the L'Edge is more stable than the Option by a moderate amount. All of them are an order of magnitude (or two) more stable than the Taureau.
Hope this helps,
Shep
Hope this helps,
Shep
At some point in the near future I should have a demo L'Edge hanging about here in upstate NY, in addition to all the C1's folks are always welcome to try out. I'll be posting up more when it appears.
I suspect if you posted up your location though you could likely hook up with someone that has one and is willing to let you paddling it around a bit.
