something new is coming!
pmp
Post by pmp »
Something new from esquif, here is a visual clue.
bubblestreet.ca
theracane.ca
hazardharry
Re: something new is coming!
Post by hazardharry »
is that a pile of moose dung?
gumpy
Post by gumpy »
The moose had a diet rich in beets!
Joe
Randy Dodson
Post by Randy Dodson »
A Spark Jr.
Parrot Head Paddler
Wendy
Post by Wendy »
The new red camo Spark is gorgous. I saw the pic on FB
Isn't "red camo" an oxymoron? "Orange camo" would be even better.
pmp
Post by pmp »
Whew, sweet ride indeed. Red is definitely faster! Well, it looks faster... and based on one run, using low tech timing, it shaved as much as 3 seconds over the duration of a 1 min. course. oh and it is approx. 3lbs lighter than the brown camo one I weighed.
paul
bubblestreet.ca
theracane.ca
kaz
Post by kaz »
Let's just hope it's not too light to race in the REC class, if you care about that sort of thing. Smerda will have his scale calibrated!
At 11'8", or whatever, it would have to weigh slightly less than 42lbs to be legal to race.
JKaz......
canotrouge
Post by canotrouge »
How is it lighter??
Randy Dodson
so do I win one since I guessed correctly? :roll:
Parrot Head Paddler
pmp
Post by pmp »
well, using unreliable bathroom scales, it measured a couple pounds lighter than the spark i was comparing it to. to be honest, I would think there could be a slight variation from boat to boat, Craig smerda could offer a more valid opinion on that.
as for speed. if you think your boat is fast, you'll go faster.
bubblestreet.ca
theracane.ca
That is a *much* better color - I approve. Red is definitely faster.
Todhunter
Ridge Spirit Outfitting
Post by Todhunter »
The laws of physics state a red boat is faster if it is moving away from the observer...a blue boat is faster if it is moving towards the observer. The ideal race boat will be blue in the front, red in the back. 8)
Matt Todhunter
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
So... for REC canoes the rules read as follows.
Article IV: SPECIFICATIONS OF CANOES
A whitewater open canoe is a traditional open Canadian or Indian canoe which is a boat with ends pointed and higher than the middle, symmetrical side-to-side, and propelled with single bladed paddles. There will be two categories of canoes. They shall be known as Recreational (REC) and Racing (RAC). Canoes of the Racing classifications are built and used with racing as the primary intent, whereas Recreational canoes are built and used primarily for recreation. The Recreational classes are included so that a large number of whitewater paddlers can race without investment in special equipment. It must be emphasized that National Championship race classes exist for both. The REC Classes are intended to include canoes sold for general recreational use. A recreational canoe must be or have been a commercially available, general production model to qualify for REC Classes. Recreational and Racing canoes can be made of any hull material. Recreational canoes shall be defined by their weight: they shall weigh at least 3 pounds per foot of length plus 6 pounds. There is no minimum weight requirement for racing canoes. A Recreational canoe may be used as a Racing canoe. Cutting down the hull of a Recreational canoe is allowed provided the ends remain higher than the center.
Just put some water in the airbags to make it the legal weight. :lol:
