Vajda Martikan Slalom C1 For Sale (Never Been Paddled!)
AdamVG
Post by AdamVG »
Maker: Vajda
Model: Martikan C1
What: Composite Slalom Racing Boat Designed by Michal Martikán
Length: 4M
Ideal Weight Range: 120-190 lbs.
Colors: Deck: Blue, Hull: Green
PicsArt_1432599185118 (400x192).jpg (101.44 KiB) Viewed 9347 times
20150525_195642 (400x225).jpg (139.23 KiB) Viewed 9347 times
Boat has never been paddled! No marks at all on hull or any foam/straps glassed inside.
Boat is located in Potomac, Maryland.
Price: $950
Adam Van Grack
President/Chair
Potomac Whitewater Racing Center
http://potomacwhitewater.org/" onclick="window.open(this.href);return false;
vangrack (at) gmail (dot) com
KNeal
Re: Vajda Martikan Slalom C1 For Sale (Never Been Paddled!)
Post by KNeal »
I cannot readily find more information about the Martikan c-1 slalom boat. 4-meter boat means it is the older 13-foot, 2-inch model. Do you have any performance characteristics you could post about it? It is a pretty sweet boat.
AdamVG
Post by AdamVG »
MORE DESCRIPTION:
This boat is the older 4M/13.2FT cut. It has been stored indoors since shipment to the US directly from Vajda, and never been paddled or had a seat installed. It was Vajda's last 4M model before the cut down.
PERFORMANCE CHARACTERISTICS: This Martikan C1 will be significant faster on a straight line and be able to surf faster waves than any of newer 3.5M boats. It will be also more stable. However, pivot turns will take additional effort and quick turns will not be as sharp. That said, this was Vajda's last 4M boat, so it turns about as nicely as any 4M C1 I've seen.
(While I have not paddled this particular boat, I know about the model from past boats of the same model)
