It's an OC1... It's a C1... It's an Esquif Taureau HYBRID ?
Thanks Craig as OC1 should enhance dryness
The boat was really dry for me in big water, but this will enhance it!
Re: Thanks Craig as OC1 should enhance dryness
Big Water... big drops... big everything!Wendy wrote:The boat was really dry for me in big water, but this will enhance it!
Well... that and because I can never leave anything alone/stock.
RodeoClown
- BlackFly Canoes
Hybrid Taureau
Awesome job Craig!!!
Those hatches look really sweet.
I noticed yours has two holes for inserting the flotation bags in the stern. Did you cut the extra hole in the foam wall in the stern or are they coming that way now?
Mike
Mike
- squeakyknee
Re: Hybrid Taureau
The holes came that way.... I haven't even touched the outfitting yet though... still need to carve out the leg holes, etc.Mikey B wrote:Awesome job Craig!!!
Mike
Hope to see you again this summer... how's that combat roll coming along for you?
Taureau
Craig, I'm really hoping to make it out your way a few times this year. I really, really want to make it to Wausau and definitely spend another day at Pemene.
I'm also trying to work on the wife for the "It Ain't Louie Fest."
I cut some foam from the outer edges and added a bit to the inside edges of the cut-outs and it seems to make a tremendous difference for rolling. It finally feels as easy as rolling my Delirious. I've been bomber on everything here, and hopefully that transfers to out there in the bigger stuff
I wish I was closer. I've been trying to figure out flatwater cartwheels in the Deli. I can do bow stalls and get vertical on the stern , but trying to figure out how initiate for cartwheels is tough.
Any ideas from anyone would be greatly appreciated.
Oh, do you think the hatches are going to get in the way any when open for getting stuff in and out vs. the removeable type hatch covers?
Mike
Mike
Re: Sweet....
It's pretty roomy in there bud... I can wear Snowshoes!JoeS wrote:I wish my Y had that much legroom.Three UP!
Joe S
I've some experience with various hatches - heck, I've got two kinds on one boat. I think the screw in kind might be more secure/watertight, but you have to watch sand and grit getting in the threads or they get nearly impossible to open and close. The sort with the latch have leaked on me - the rubber seal doesn't quite do it (age? overcompression?). The best are on a sea kayak (I know, I know) by Valley that have a tight rubber cover that's better than tupperware (tm). Those coupled with welded bulkheads are dry as a bone - I don't even use a dry bag for my sleeping bag. Not sure if those are available separate from a boat, though...
