Good rolling technique
Post all your CBoat and OCBoat related videos here!
coloradopaddler
Post by coloradopaddler »
it usually isn't too "merry" when i roll! combining a high brace sweep and a low brace roll is what i was trying to say i don't do. i'm going paddling soon so i'll see if i can get this out quickly.
i paddle left, if i was going over towards the right, i would tuck with my paddle's power face on my bow deck. to do that i put my t grip hand in my belly and my shaft hand up near my head (since it's tucked). so, my t grip hand thumb is still pointing left but the paddle is now out in front of me. once i'm over, i sweep out to a low brace position and hip snap. a flip to the left would be the same except for the set up, which isn't needed. just get the blade out to ninety degrees and hip snap! i'll take the camera and see if i can show it clearer.
Smurfwarrior
Post by Smurfwarrior »
Can someone explain what a 'screw roll' is?
coloradopaddler
when you screw up you have to roll! sorry, i don't know i've heard of a roll all the way around called a barrel roll.
cadster
Post by cadster »
Smurfwarrior wrote:Can someone explain what a 'screw roll' is?
I thought you kayaked?
A screw is a kayak roll with a weak hip snap and finishing with a backward lean.
Canoe rolls rely on a strong snap which includes more of the upper body. I'd call Craig's roll a kayak roll since he's coming up on a high brace.
My shoulder hurts just thinking about a high brace roll in an OC-1... C-1, maybe... I heard Lugbill's roll described as "a monster forward stroke that started from under water" (or words to that effect).
cadster
Post by cadster »
Here's a roll without any setup:
http://www.youtube.com/watch?v=S8qdFVZLP4w
FullGnarlzOC
Post by FullGnarlzOC »
That's a low brace where i come from. No setup needed.
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
Todhunter
Ridge Spirit Outfitting
Post by Todhunter »
I've been trying to roll / looooooooow brace in the pool for a few weeks now. I am not doing any kind of forward sweep - maybe I will give that a shot next time I hit the pool. These videos and descriptions are great - I really need a roll!
FullGnarlzOC wrote:That's a low brace where i come from. No setup needed.
If both gunwales get wet, its a roll.[/list]
cadster
Post by cadster »
If it was a low brace, the paddle would have ended up rotating over with the boat.
For the paddle to change sides, you have to let the shaft hand slip and hang under the paddle when fully upside down.
coloradopaddler
here is a link to me doing a low brace roll.
http://www.youtube.com/watch?v=EYbUqWfymdY
Smurfwarrior
Not sure if you can view this, its a FB vid but its got the clearest view I've yet to see.
http://www.facebook.com/home.php#!/vide ... 8850797104
cadster
Paddle Flip or No
Post by cadster »
I do both the Foote and Ford rolls, but I think of them as paddle flip versus no paddle flip.
The Ford roll is faster since there isn’t the pause to flip the paddle when it’s out to the side. If your flip timing is off the paddle will dive. It doesn’t need the setup like Coloradopaddler shows even when going over to your offside.
I try the Ford roll first, but if that doesn’t work I go to the Foote setup because I like the tighter tuck you get by reaching forward versus having the paddle in your gut.
Todhunter
Post by Todhunter »
Smurfwarrior wrote:Not sure if you can view this, its a FB vid but its got the clearest view I've yet to see.
That is the video that I have watched over and over and have been trying to emulate.
Kelvin
Post by Kelvin »
Hi Folks,
Just a quick one. The scull out and flipping the paddle over is only a set up, there is no pressure during this phase. I sometimes go under back deck, sometimes knife the blade to the surface.
Also, the Zoom doesn't usually stall! In this instance there is no underwater scull, I just hang in there in the set position.
Kelvin.
P.s. It's not a good idea to set with the paddle on the deck with the T-grip in your belly, T-grip hits rock... etc.... etc.
