Plan was to put Larry's saddle in there. The boat came with both plastic-reinforced foam pillars, and a rod that runs through them both, acting as a hull stiffner but that doesn't touch the hull, up by about half an inch. The rod was on the way so I had to pull it out.
I thought the boat was light (cool!) but when I put the hull upside down, with both pillars in place, I can very easily, pushing with my small finger, make the bottom of the boat move by about two inches. No jokes.
Sunny side up, If I put my weight (165#) on the side of the cockpit rim, it moves down about one inch. I can twist the rim a bit quite easily too.
The boat back to the retailer right away. We get to compare it with similar JK crosslink boats hanging around the shop, those are more stiff then mine but not so much. The kayak seats are helping making the boats more sturdy for sure, but since the same rod is there as hull stiffner, you can make the bottom move half an inch, until you hear it touching the rod, quite easily.
The retailer calls at Jackson and are being told this is normal. Soft hulls are not a point of warrantying/replacing a hull anyways; it needs to be broken.
Now I don't know what to do. Would really appreciate to get other people's advices and experience on that type of plastic for C1ing. I know others (bernie?) have successfully outfitted jackson hulls, was it PE or Elite plastic? I have owned and outfitted 3 other boats (perception amp, dagger ultrafuge, LL Remix 69) and all three were much much stiffer than that. I could stand on the empty hull and it would move the bottom a bit but not that much... If I do it with this boat I might very well get a touchdown. Am I worried that hull oilcanning under me and it's brand new. Larry's saddle would for sure add a lot of structure and that would maybe set it but shouldn't a boat be able to hold up on its own first off? Now I am being told I absolutely have to put a wood twarth and bulkhead for reaching the cockpit rim. I even got told by the retailer I need my seat to reach from bottom to the sides of the cockpit around the middle, like kayak seat do. me: "well, my legs are there"
Overall although the boat has one year warranty I am sure I won't exactly break it the first year since I'll be using it on safe playspots, no rock banging, about 10-20 times a year or so... So being told there's a warranty doesn't reassure me much more.
Sorry for the long post, any help/advices would be appreciated...
