Jackson is in the Canoe Business!! C1 out fitting
johnd
Post by johnd »
I sure would like to have a Jackson playboat as a C1, it would be the perfect complement to my open boat. Open boat for challenge, C1 for play. I might go for something like this. A nonbiased, objective review would be eagerly read.
busterblue
Post by busterblue »
Ditto.
scott curtis
Post by scott curtis »
how much for the cheese larry?
AJ
Post by AJ »
PatrickOC1 wrote:I wonder what Big Dog kayaks C1 setup looks like compared to this, spoke with a dealer of theirs at the Deerfield river fest from RI said he hasnt seen it yet and his boss wont order any says its a waste of money to Import. Even though I was like the 7th person to ask about them.....think jackson might take their market if they dont move a little quicker markets only so big.
From what I have seen, Big Dawg C products are a bunch of hype, nothing ever gets to market. I don't think I have ever seen a Big Dawg boat in Colorado?
I would rather support a USA company, if they are investing and building quality C products. Plus, EJ and Dane paddling C1, gives Cboating a ton of exposure to people that wouldn't even consider Cboating.
I know some of you glue sniffin, outfitting tinkers wouldn't consider them, even if it was a good product. :wink: Some people want to buy a boat and paddle. If the basic C guts are in the boat, you can still modify to meet your needs.
I have to agree with Sir Adam, lets see what they have to offer, before passing judgement. We all want more Cboat options and new products and at least Jackson has stepped up.
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
it's hard to believe no one is diving headlong into the C1-ish marketplace based on the reactions here?!!!? :roll: :lol:
only time will tell if it's a winner or loser... but let's at the very least give 'em credit for putting something out there.
here's the big ?
what else might it fit? can the base be purchased without the other "stuff"?
man... tough room... :P
tennOC
Post by tennOC »
They should certainly sell just the "kit", and here's an idea-- a "conversion" where you can cut a kayak paddle in half and attach C-1 conversion handles. It follows this same line of thinking of taking an otherwise useless shape and converting it into something usefull.
BrownDog Boats- "Bring the Dog"
Craig Smerda
L'Edge Designer
well Larry I think you may be right... there's already a lot of people more than comfortable wearing a K1 skirt... so next it'll be paddle conversions... clearly the "transition" is already half the way over.
:( ~sad~ :(
Post by Larry Horne »
no craig, the real question is....is it held in place by zip ties.. or accessory cord...?
oopsiflipped
Post by oopsiflipped »
really craig? you just figured out there really is no market for a plastic c1? :wink:
old
Post by old »
Well someone tries to do what most everybody wanted to see and what do they get? bitch, moan, bitch moan.......
Y'all would bitch if we hung you with a new rope!!!
Hey Tim, What rapid is this?
I've been thinking about this - the pedestals Perception and Dagger made are just thermoformed ABS or PE aren't they? How hard can that be do have done? I know folks form their own kydex sheaths and holsters...
Post by Bob P »
sbroam wrote:I've been thinking about this - the pedestals Perception and Dagger made are just thermoformed ABS or PE aren't they? How hard can that be do have done? I know folks form their own kydex sheaths and holsters...
"All you need is" a really big (and accurate) oven, a good vacuum pump and the molds. I've done much smaller parts and the whole process is pretty sensitive. At $120 (very loose guess), the break-even quantity would probably be 50-100 pieces, in my humble estimation, assuming I already had the oven.
Hmmm... I could probably come up with a fabricated aluminum pedestal design that you could Pop-rivet together (after trimming to fit your hull's profile) for under $100. It would require a Minicell addition on the top for comfort.
I was thinking about approaching a local manufacturer (don't have one in mind, but surely they're around) to see what it would take.
Personally, though, the "plate" conversion +/- the fence rail (or other similar backbone) bit are pretty easy and portable to a new boat...
Post by Bob P »
On one of my early (!) conversions of a Dancer, I made a tubular framework that hung between the bow deck and the stern deck. The foam seat keyed in between the tubes, which dipped within about 3" of the hull. The thigh straps attached to the tubes in front of the foam. That design would be relatively easy to do, but would likely only fit one hull design.
scott curtis wrote:how much for the cheese larry?
that's what I want to know!
