Twiggy
Glueing D- Rings?
Glueing D- Rings?
I almost got my XXX converted, shaped a pedistal myself that Im pretty proud of
, and some nice knee cups. Im just having one problem, My D Rings wont stay glued in. Im using Liquid Nails Contact Cement, following the directions and everything. It just wont stay glued solid. Any suggestions? Thanks
Twiggy
Twiggy
NZMatt
- Supporting Paddler
see other thread
Hi Twiggy
There was a recent thread on glueing polyethylene. It basically suggested couple of specific glues for PE (virtually nothing sticks to PE). Liquid nails probably just won't bond with PE. Scroll down in the forum or do a search and you should find it
Cheers
Cheers
NZMatt
- Mike W.
Suggestions
If you want thigh straps, click "TEAM etc" over to the left on this page. Or, just make a bulkhead.
I did the TEAM etc. when I converted my Big EZ. It's a great system. A couple of weeks ago I added a bulkhead that keeps my knees planted in the boat. It's the best thing since the tall seat
Mike W.
Mike W.
Team etc
I think I sent photos to you of my XXXs modified team etc. You could make a different version as well using the existing seat holes and a sheet of the plastic, running from one site to the other with stap mounting points between. If you want PM me and I'll send you some more photos with better details.
Mike is also right that you can modify the piller for that use as well - hopefully making your customized seat even cooler!
I can send you some photos on that as well.
Good luck!
Good luck!
