Robson Homes PE
- bushpaddler
Robson Homes PE
News from Bavaria, no prices available yet, but at least some pictures...
- TheKrikkitWars
Re: Robson Homes PE
Someone has clearly seen which way the wind is blowing...
PatrickOC1
Re: Robson Homes PE
I see thigh straps
any word on weight etc?
Re: Robson Homes PE
Anyone paddle that design before?? It looks wet. Good for vertical move though?
Re: Robson Homes PE
It would be very interesting to put one side-by-side with a Prelude. Looks like they might be similar in the speed/dryness categories.ian123 wrote:Anyone paddle that design before?? It looks wet. Good for vertical move though?
Re: Robson Homes PE
Have seen the Amerlite version, but never paddled.... always wanted a plastic one.
Looks really dry, and likely to have nice speed. I'm sure one of our European boaters will have worn one (or two) out by now. Believe this was the last Frankie boat, although never have substantiated that.
Re: Robson Homes PE
Simply because
Spanish Fly paddlers ...
... can paddle most-every thing dry.
PatrickOC1
Re: Robson Homes PE
Id say it looks real similar to a prelude well from those angles.....
Re: Robson Homes PE
That looks awesome (like a prelude with harder edges! What more could you want?), but I'm guessing it will be another robson boat we rarely see on this side of the ocean.
It does look like it would fill the "slightly faster than the L'edge/Option" niche, though.
-Anthony
Re: Robson Homes PE
From the Robson site:PatrickOC1 wrote:I see thigh strapsany word on weight etc?
length 296 cm
width 70 cm
height Bow 48 cm, Center 40 cm
weight 24 kg
volume 380 ltr.
material PE-Superlinear
capacity 120 kg
-Anthony
- Todhunter
- Ridge Spirit Outfitting
Re: Robson Homes PE
For us metrically challenged folks...TNbound wrote:From the Robson site:PatrickOC1 wrote:I see thigh strapsany word on weight etc?
length 9' 8.5"
width 27.5"
height Bow 19", Center 15.75"
weight 53 lbs
volume 100 gallons
capacity 265 lbs
Matt Todhunter
avlclimber
Re: Robson Homes PE
For us non-metric Americans:
length 296 cm > 9' 8.5"
width 70 cm > 2' 3.5" (27.5")
height Bow 48 cm, Center 40 cm (18.8", 15.7")
weight 24 kg > 52.9 lbs
volume 380 ltr.
capacity 120 kg > 264.5 lbs
That is pretty awesome turn-around from the suggestion 4 days ago in this thread:
https://cboats.net/cforum3/viewtopic.ph ... 2&start=15
That's a sweet looking boat.
volume 380 ltr.
Re: Robson Homes PE
More feet for meters ====> viewtopic.php?f=2&t=7965837&start=13" onclick="window.open(this.href);return false;
not copyrighted - from: Hydrocarbon Processing, 1981 April
